- Choose the Right Material for Your Roof
Insight: If you’re planning to use asphalt shingles—the most common choice in Quebec—opt for fiberglass shingles (also known as compound shingles). They’re lighter and more resistant to extreme temperature variations compared to traditional organic types.
For gentle roof slopes, standard three-tab shingles are usually sufficient.
For steep roof pitches, consider architectural shingles, which offer enhanced durability and design.
- Use the Proper Tools
Insight: Effective repair work depends on having the right gear:
A shingle scraper to remove old shingles cleanly.
For installation, either a pneumatic nailer or a roofing hammer.
Use galvanized roofing nails, in sizes of 1¼″, 1½″, or 1¾″, to ensure long-lasting hold.
- Plan for Debris Removal
Insight: Disposing of old roofing material—especially shingles—can be cumbersome:
Traditional disposal often involves renting a truck and delivering debris to a municipal ecocenter.
As an alternative, container rental services, like those offered by Recybac (in Montreal and nearby regions), provide a convenient solution: you simply load the debris into the container, and the team disposes of it properly.
- Prioritize Your Safety
Insight: Roof work carries real risks—so safety must come first:
Wear rubber-soled shoes for traction.
Use a safety harness when working on any roof.
For steep slopes, it’s wise to install scaffolding.
Summary Table
Tip Key Considerations
Material Selection Favor fiberglass shingles; choose three-tab for flat roofs and architectural shingles for steep pitches
Proper Tools Shingle scraper, pneumatic nailer or hammer, and galvanized nails (1¼″–1¾″)
Debris Disposal Utilize container rental services to simplify cleanup and avoid handling waste yourself
Safety Measures Use non-slip footwear, harnesses, and scaffolding to minimize hazards during repairs
