Painting is often the last thing to finish the renovation of a basement. But not all paints are safe, particularly in enclosed areas where there is limited ventilation. Many traditional paints emit volatile organic compounds (VOCs), chemicals that can result in strong odours, headaches and long-term health risks. That’s why the low-VOC paints are the smart choice for basements.
Low-VOC paints are specially formulated in order to limit harmful emissions. They create minimal to no toxic fumes, which makes them safer for the homeowner and workers during and after renovation. This is particularly important in the basement where air circulation tends to be less than in the rest of the house.
These kinds of paints don’t cut corners when it comes to quality either. Available in a wide range of colors and finishes, low-VOC paints offer the same durability and beauty as standard. Many brands are also now available with washable and moisture resistant formulas which are ideal for high humidity areas such as basement areas.
Using low-VOC paints adds to the benefits of good indoor air quality, which is better for respiratory irritation and can make the basement a healthy place to relax, work, or play.
Low-VOC paints are more than a matter of style - they’re a matter of health In the basement renovation, they safeguard the quality of the air in the home without compromising beauty or durability. A fresh coat of low VOC paint doesn’t just brighten up walls, it’s a way to make the environment safer and healthier for everyone at home.
