Beginners guide on how to fix your tiles by yourself like a professional
‎Here’s a simple, step-by-step guide to tiling your floor alone at home, written for beginners and DIY homeowners. Take your time, good preparation is the secret to a professional look.
‎🧰 Tools & Materials
‎Floor tiles
‎Tile adhesive (thin-set mortar)
‎Grout
‎Notched trowel
‎Tile spacers
‎Spirit level
‎Tape measure
‎Tile cutter (manual cutter or grinder)
‎Rubber mallet
‎Sponge & bucket
‎Chalk line or pencil
‎Safety gloves & goggles
‎STEP 1: Prepare the Floor (Very Important)
‎1. Remove furniture and old flooring
‎2. Sweep and mop the floor
‎3. Ensure the floor is flat, dry, and strong
‎4. Fill cracks or holes with cement or floor filler
‎5. Let it dry completely
‎Tip: Uneven floors cause cracked tiles later.
‎‎STEP 2: Plan the Tile Layout
‎1. Measure the room and find the center
‎2. Snap chalk lines to create a cross
‎3. Dry-lay tiles (without glue) to check alignment
‎4. Adjust so cut tiles go to the edges, not the center
This prevents tiny, ugly cuts.
‎STEP 3: Mix Tile Adhesive
‎Follow manufacturer instructions
‎Mix until thick but spreadable (like peanut butter)
Only mix what you can use in 30 minutes
‎STEP 4: Apply Adhesive
‎1. Spread adhesive on a small area (1–2 m²)
‎2. Use the notched side of the trowel
‎3. Create straight grooves for better bonding
‎STEP 5: Lay the Tiles
‎1. Start from the center lines
‎2. Press tiles firmly into the adhesive
‎3. Use tile spacers for even gaps
‎4. Tap gently with a rubber mallet
‎5. Check level after every few tiles
‎Work slowly, accuracy matters more than speed.
‎‎STEP 6: Cut Edge Tiles
‎1. Measure the gap
‎2. Mark the tile
‎3. Cut using a tile cutter or grinder
‎4. Dry-fit before fixing
‎Always wear goggles when cutting.
‎STEP 7: Let Tiles Set
‎Leave tiles undisturbed for 24 hours
‎Do not walk on them
‎STEP 8: Apply Grout
‎1. Mix grout
‎2. Spread diagonally across tiles
‎3. Push grout into gaps fully
‎4. Wipe excess with a damp sponge
STEP 9: Final Cleaning
‎‎After 30 minutes, clean grout haze
‎‎Let grout cure for 24–48 hours
‎‎Seal grout if recommended
‎‎Pro Tips for Tiling Alone
‎Work in small sections
‎‎Keep adhesive off tile surfaces
‎Use knee pads to reduce fatigue
‎‎Start early so you’re not rushing
‎Common Mistakes to Avoid
‎‎Skipping layout planning
‎Applying adhesive to large areas at once
‎Walking on tiles too early
Uneven adhesive thickness
you are on point Buddy keep it up man
Well written article
Thank you for sharing
You said a lot here mate
Really love this, keep it up
What a nice piece of information
