Building a UL-1618 Type 1 floor protector?
I recently purchased a wood stove that details in the manual
The floor has to be safeguarded with a minimum 3/8 inch thick UL-1618 Type-1 floor pad, crafted from non-combustible materials
I would like to explore how to effectively install this floor protector to ensure safety and compliance while enhancing the overall aesthetic of my space. Additionally, I’m eager to learn about the best practices for maintaining the pad and ensuring it serves its purpose for years to come. Building a UL-1618 Type 1 floor protector?
To keep your floors safe from your wood stove, you’ll need a UL-1618 Type 1 floor protector. Think cement board covered with tile, stone, or metal something that won’t catch fire. You can either build one yourself from the right stuff or get a pre-made pad that’s already certified. If you’re going the DIY route, make sure you stick to the clearance rules for your stove and that it’s thick enough. To finish it off, don’t use anything flammable under the stove keep it clean and safe. Pick out materials that look good with your room. Clean it every so often and keep an eye out for any cracks or damage.
To build a UL-1618 Type 1 floor protector, use at least 3/8-inch thick non-combustible materials like cement board topped with tile, stone, or metal. Ensure it extends the required clearance around the stove per the manual. Install it on a flat, stable surface and seal edges to prevent debris buildup.
For maintenance, sweep regularly, avoid water pooling, and inspect for cracks or delamination. A well-built pad protects both your floor and your home while adding visual appeal.
