California/Oregon WUI: how should windows be selected (tempered, DP ratings) for radiant heat exposure?
For better heat protection, get dual-pane windows with tempered glass. Also, make sure they can handle the wind in your area. Windows with metal outside and low-E glass can help reduce heat. If you’re in a fire prone area, go for good seals and frames made of aluminum or fiberglass. They’re safer!
Choose tempered, dual pane windows with high DP ratings and low-E, low SHGC glass; frames in metal, fiberglass, or clad wood; all rated for WUI ember and radiant heat resistance per local code.
