Can a general contractor handle demolition work, or do I need to hire a separate demolition contractor for my project?
Yes, a general contractor can handle demolition work! Many have experience and crew for that. Just make sure to check their qualifications and past projects to ensure they can manage it safely and effectively.
General contractors handling demolition is like trusting King Kong with your project—pro if skilled, chaos if not. Check creds: LinkedIn Login, Sign in | LinkedIn
So, your general contractor can probably handle small demolition jobs. But when things get risky, big, or involve hazardous materials, it’s better to bring in a specialized demolition contractor sometimes the law even says you have to.
Yes, a general contractor can handle demolition if licensed and insured, but specialized contractors may be needed for hazardous or complex projects.
A general contractor can usually handle demolition, but large, hazardous, or specialized tear-downs may need a licensed demolition contractor.
A general contractor can usually handle demolition, especially small to medium jobs, as they coordinate subcontractors and permits. You only need a separate demolition contractor if the project is large, hazardous (asbestos, lead), or highly specialized.
Most general contractors can handle demolition, but large or hazardous jobs may require a specialized demolition contractor for safety and compliance.
Yes, a general contractor can handle demolition work. While demolition is often specialized, a general contractor can manage the entire process, including hiring subcontractors like demolition specialists if needed
