Can i use plumbing solder for electronics?
Can I use plumbing solder for my electronics projects, or is there a better option that won’t damage the components?
Using plumbing solder in electronics projects ain’t recommended. It usually contains lead and is thicker, which can damage delicate components. Better option is to use rosin-core solder, specifically designed for electronics. It has lower melting point and cleaner joints—perfect for your project!
