Cheap Materials Are Expensive: The Truth They Don’t Tell You in the Shop
Many people fall for the trap of “let me just manage this one for now.” Unfortunately, renovation doesn’t forgive cheap mistakes. Low-quality cement means cracks. Weak pipes mean leaks inside the wall. Cheap roofing sheets mean noise during rain and early rust. You end up repairing the same thing again — paying double.
When buying materials, don’t just listen to sellers — they are not your financial advisor. Their job is to sell. Your job is to think long-term. Ask your contractor for specifications and then cross-check with an independent person, not just the same supplier your contractor brings (some get commission).
Another tip that feels small but matters: store materials properly. Cement sitting in moisture gets weak. Tiles stacked badly break. Paint exposed to heat spoils. People lose money before installation even begins because materials were dumped anywhere like sand.
Real renovation wisdom is simple: strong foundation, strong structure, strong hidden materials. Fancy lights and décor are easy to upgrade later. But pipes inside the wall, beams, waterproofing, and wiring — if they fail, everything fails with them.
thanks for putting this out
I tell you, you’re on point this time
Thanks for bringing this to our notice
Thanks for this information bro
You are always on point Buddy
