Choosing Between Wall-Hung and Floor-Mounted Fixtures
Wall-hung toilets and vanities make the bathroom look modern and easier to clean underneath. However, they require strong wall support and proper installation. Floor-mounted fixtures are simpler and cheaper, but take up floor space.
During renovation, choose based on budget, wall strength, and maintenance, not just style. Both options work well if installed correctly. The key is proper fixing so there are no future cracks or movement.
well detailed article
Thank you for sharing this with us
This article helped me approach the topic with more confidence
You are so on point lad
Keep on the good work
