Cleaning/maintenance: what surface treatments or cleaning methods are approved for traction/soiling control on tiles, a…
Cleaning/maintenance: what surface treatments or cleaning methods are approved for traction/soiling control on tiles, and do any create slip or electrical hazards?
To keep your solar tiles in tip-top shape, give them a wash with some mild soap and water using a soft brush or sponge. Just remember, don’t scrub too hard or use a pressure washer! It’s best to do this when the tiles are cool, like in the early morning or late evening. Oh, and make sure to turn off the solar system beforehand. One more thing: stay off the tiles when they’re wet because they can be super slippery, and you don’t want to risk cracking them. Cleaning them the right way helps them to work well and keeps your system up and running without any problems.
Approved surface treatments for improving traction and controlling soiling on tiles include anti-slip coatings (such as epoxy or urethane-based), acid-etching or mechanical texturing, and non-slip sealants. These treatments are designed to reduce slip hazards and do not pose electrical risks when used correctly. Textured mats or grip tapes are also effective for traction but can become trip hazards if not properly secured.
For cleaning, pH-neutral cleaners used with mops or microfiber pads are safe for regular use and pose no slip or electrical risks. Steam cleaning is effective for deep cleaning, but it should be used with caution around electrical outlets to avoid shock hazards. Alkaline cleaners are useful for greasy areas like kitchens, but they must be rinsed thoroughly to prevent slippery residue. Dry sweeping and vacuuming are safe and effective for removing dust and debris without introducing moisture-related hazards.
Avoid oil-based cleaners, waxes, and excessive water use near electrical outlets, as these can increase slip or electrical hazards. Always test any treatment in a small area first and ensure floors are properly dried after cleaning to maintain safety.
Approved Surface Treatments for Traction/Soiling Control on Tiles
  1. Anti-Slip Treatments: Chemical coatings, textured mats, and tapes can enhance traction on tile surfaces. These treatments work by increasing the coefficient of friction between the tile surface and footwear.
  2. Penetrating Sealers: These sealers soak into the tile and don’t form a film on the surface, reducing slip hazards. They’re ideal for porous tiles like natural stone.
  3. Topical Sealers: These sealers form a thin film on the surface, acting as an absolute barrier. However, they can increase slipperiness if not applied correctly.
  4. Nano Anti-Slip Floor Coating: A clear, innovative solution that increases slip resistance on tiles, suitable for interior and exterior areas.
  5. Epoxy Coating: A durable, moisture-resistant coating that can be applied to tiles to enhance traction.
