Glass wall as a wall between the floor and the ceiling has grown to be a characteristic of the modern living room as it allows the introduction of the natural light and the clear connexion with the outside. These broad windows, in contrast to traditional windows, are much more transparent in that they do not define the line between cosiness inside and out and, by doing so, provide the homeowners with a feeling of freedom and opulence.
The abundance of daylight is one of the biggest benefits, as it minimises the use of artificial light and increases the atmosphere of the area. Regardless of the view of a garden, urban landscape, or a sea, glass walls turn the environment into a part of the interior design. They are also used as complements to minimalist and contemporary designs as they focus on good lines and openness.
Nevertheless, glass walls in a living room must be planned. The problem of privacy can be resolved through tinted, frosted or smarter glass which can change the level of transparency when it is requested. It is also necessary to have thermal insulation, which should be double or triple glazing, to control the temperature and make the energy prices lower. Glass and smooth curtains or automated blinds make it possible to be flexible in terms of appearance and comfort.
Finally, living rooms are turned into sunny and welcoming spaces with the help of floor-to-ceiling glass that glorifies modern architecture. It is not as much as design but all about lifestyle; closeness to nature and still remaining sophisticated in interior design.
