Durability and safety in clubs and supermarkets are very dependent on the materials used for fixtures and fittings. Corrosion-resistant metals are one of the factors to consider when you expand and want to ensure performance for years while being used and exposed to water.
Stainless steel, aluminium and galvanised metals are popular options. Stainless Steel does not rust even in moist places such as bars, kitchens or restrooms. Aluminum is lightweight, strong and is naturally resistant to corrosion, making it perfect for shelving, railings and decorative trims. Galvanized metals, which are coated with zinc, provide long term protection from water and wear.
Fixtures such as railings, window frames, display racks and handrails are all susceptible to damage when inferior metals are used. Rust not only compromises safety, but also aesthetics, giving a worn out or neglected appearance to newly renovated spaces. Using high quality, corrosion resistant metals ensures that these problems do not occur and that the maintenance costs are lower in the long run.
Beyond the practicality of things, these metals can improve design. Sleek stainless steel accents in a club or polished aluminum shelving in a supermarket have the look of modern, professional, and is functional at the same time. Correct installation and some maintenance are all it takes to keep these materials performing well for years to come.
Corrosion-resistant metals are a little goes a long way. By selecting the appropriate material for fixtures and fittings, clubs and supermarkets create durable, safe and visually appealing spaces. This investment helps protect the customers and the facility for a successful and long lasting expansion.
