STUD‑SPACING SHOWDOWN — Day 6 Summer‑Series Mini‑Quest
Today you’ll flex real‑world reno math. Tape measure in one hand, calculator in the other, and you’re off to the races. The blueprint for a small cabin wall is attached as wall_day6.png (simple elevation sketch—nothing fancy).
Once the fifth correct solution lands in General, the lumber yard closes and the prize rack is empty. Ready to frame? ![]()
The Job Site
The drawing shows one exterior wall with these specs (all dimensions are already marked‑up on the sketch):
| Item | Detail |
| Wall length | 22 ft 0 in |
| Wall height | 8 ft 0 in |
| Openings | • 36″ × 48″ window — centred 6 ft from the left end to its RO centre line |
| • 32″ × 80″ door — 5 in from the right end to its RO edge |
Use standard North‑American light‑frame rules throughout:
- Stud spacing: 16″ on‑centre (O.C.)
- Each opening gets two king studs (full height) on each side
- Ignore trimmers—count only king/full‑height studs
- Floor system joists also run 16″ O.C. (rim joists excluded)
- Two‑ply 2 × 10 headers over every opening
Prize Pool
150 000 $RENOVATION coins to each of the first five correct solvers.
Where to Post
Open General → New Topic → Stud‑Spacing Puzzle —
What to Include
- Decoded mantra (three letters, sorted alphabetically, any case)
- Your Solana wallet address (one per member)
Tiny Trail of Breadcrumbs
- A — Stud Count
2.Formula*:⌊wall_length_in/16⌋ + 1 + (4 king studs × 2 openings) - B — Joist Count for a 11 ft 0 in clear span floor (again 16″ O.C., rims don’t count).
- C — Header Plies
5.Two‑ply 2 × 10* over each opening → just total the individual planks you’d buy.
Convert each answer to a letter with the classic A1Z26 scheme (1 → A … 26 → Z).
Sort the three letters alphabetically to read a familiar builder’s mantra.
Need a nudge? Remember that math.floor() is every framer’s best friend, waste is cheaper than a second yard run, and you can always subtract 26 until your number lives in the alphabet.
How to Submit
Decoded mantra: "<your three‑letter answer>"
Solana wallet: xxxx...xxxx
Smash Post. If you’re among the first five right answers, the airdrop is yours. Public TX hash follows for bragging rights.
FAQ
“Can I brute‑force it?”
You could—but a dozen keystrokes on a calculator beats 17,576 guesses.
“Multiple wallets?”
Nope—one Solana address per member. Duplicates or Sybils VOID entries.
“I’m late—can I still try?”
Puzzle stays open until slot five fills or the Summer Series wraps—whichever comes first.
Measure twice, count once, and race for that 150 k bag. Good luck, renovators! ![]()
