Replacing an outdated vanity can completely refresh a bathroom’s appearance. Fortunately, this project is manageable for most DIY enthusiasts with basic plumbing knowledge.
Start by shutting off the water supply and disconnecting plumbing connections under the old sink. Remove the vanity carefully, taking care not to damage surrounding walls or flooring.
Next, prepare the space by checking for leaks or water damage. Repair any issues before moving forward. Place the new vanity in position and mark where plumbing holes need to align. Some adjustments may be required with a jigsaw or hole saw.
Once the vanity is secured to the wall, install the sink and faucet according to manufacturer instructions. Reconnect plumbing lines, ensuring connections are tight and leak-free. Finish by applying a bead of silicone around the edges for a clean seal.
Conclusion: Installing a new vanity doesn’t require hiring a plumber or carpenter. With patience and the right tools, homeowners can modernize their bathrooms, increase functionality, and boost property value.
