Renovating a bathroom yourself can save money and give you a satisfying sense of accomplishment. With careful planning and patience, even small DIY projects can transform the space.
Step 1: Plan Your Renovation
Decide on your goals a modern look, better storage, or updated fixtures. Measure the space and make a list of materials, tools, and estimated costs.
Step 2: Prepare the Space
Clear out everything, turn off water supply, and protect floors and nearby rooms with drop cloths.
Step 3: Demolition
Remove old fixtures, tiles, or vanities carefully. Take your time to avoid damaging plumbing or walls.
Step 4: Install or Update Fixtures
Install new faucets, showerheads, toilets, or vanities. Follow manufacturer instructions and double-check water connections.
Step 5: Walls and Flooring
Paint moisture-resistant walls or install tiles on floors and shower areas. Make sure surfaces are level and sealed properly.
Step 6: Finishing Touches
Add mirrors, towel racks, lighting, and accessories. Caulk edges where needed and clean thoroughly.
DIY bathroom renovations take time, but following these steps ensures a functional, stylish, and refreshed space without hiring a contractor.
