Do storm doors help or hurt modern high‑seal entry doors?
Hey, if you’re dealing with chilly or wild weather where you live, think about getting a storm door they can really help!
Now, if you’ve got a recent, good-quality front door that seals up tight, and you’re in a place with nice weather, a storm door might not be the best idea. Unless it’s got some good vents, it could actually cause you some problems.
Storm doors can help by adding insulation and protecting the main door, especially in cold or shaded areas. However, in hot or sunny climates, they can trap heat and damage modern high seal doors. Choose vented or low-e glass storm doors to reduce heat risk.
