Drainage systems play a key role in protecting buildings from water damage. On site, drainage layout follows approved drawings to ensure proper flow. Trenches are excavated to required depth and slope.
Pipes are laid carefully and connected securely to avoid leakage. Inspection chambers are positioned at appropriate intervals for easy maintenance. Backfilling is done gradually and compacted properly.
Water tests are sometimes carried out to confirm proper flow. Blockages are cleared before final covering. Good drainage reduces dampness and erosion around the building.
In conclusion, proper drainage installation protects the building structure. Well planned drainage systems reduce maintenance problems and extend building lifespan.
