Drill bit choice affects accuracy and tool life. Trades select bits based on material and task. Using the wrong bit causes tear-out and overheating. Selection matters.
Wood bits vary by application. Brad-point bits provide clean entry. Spade bits handle rough openings. Control prevents splintering.
Masonry and metal require specific designs. Trades avoid forcing bits through resistance. Speed and pressure are adjusted. Heat is managed.
Bits are stored properly. Dull bits are replaced early. Sharp tools work faster. Wear is reduced.
Clean holes support clean installs. Hardware fits correctly. Finishes remain intact. Details show care.
Conclusion. Proper drill bit selection improves quality and efficiency. Trades who choose wisely work cleaner.
