Easy DIY Floating Shelves for Any Room
Floating shelves are a simple and stylish way to add storage and display space to any room They are perfect for books, plants, or decorative items
Step 1 Measure and mark Decide where you want the shelves and mark drill points Use a level to ensure straight placement
Step 2 Choose materials Select sturdy wood or repurposed boards Brackets or hidden mounting hardware can create the floating effect
Step 3 Install Secure brackets into wall studs to hold weight Place the shelf on top and double check alignment Tighten screws and make sure it is level
Step 4 Style Add plants, books, or decor items Use a mix of functional and aesthetic pieces to make the shelves both useful and visually appealing
Final thought DIY floating shelves show that small projects can have a big impact They save space, enhance organization, and add a modern touch to renovated rooms
Thanks for putting this out
The pictures say it all friend
Amazing article brother THANKS
Now I know what to do with mine
