One of the biggest problems with renovating a hacky and stacky house is dealing with electrical and plumbing systems. These homes are often cobbled together using shortcuts, outdated materials or unsafe DIY installations. While the walls and floors may appear to be intact, what’s underneath them often speaks a different storey - loose wires, overloaded circuits, leaky pipes and poorly connected drains are common.
Electrical safety should always be the number one priority. Faulty wiring is not only dangerous to homes in terms of fire but can be fatal to people’s lives. During renovation, all circuits should be checked to make sure they meet modern safety standards. Old wires may need to be changed altogether, as distribution panels may even need to be upgraded to cope with modern appliances. Installing ground fault circuit interrupters (GFCIs) in wet locations in the home, such as the kitchen and the bathroom, is also critical.
Plumbing is equally as important. Many hacky houses are run by old, corroded pipes or mismatched connecting pipes which result in constant leaks or water pressure issues. Renovators should be on the lookout for hidden water damage in the walls and floor, and swapping out old systems for durable materials such as PVC or PEX or copper. Proper drainage and water flow are not only essential for proper functionality, but for preventing mold and structural deterioration.
Conclusion:
Renovating the hacky and stacky house requires more than cosmetic repairs - it requires the rebuilding of safe and reliable systems. Electrical and plumbing inspections and upgrades help to keep the home safe from fires and floods and long-term damage. By putting safety behind the walls first, renovators are providing a secure foundation for the visible beauty of the finished project, ensuring that the home is safe and functional for years to come.
