When choosing between engineered wood and solid hardwood for flooring, understanding their differences is key. Solid hardwood, crafted from a single piece of wood, offers timeless beauty and durability. It can be sanded and refinished multiple times, extending its lifespan to decades. However, it’s prone to warping in humid environments and requires regular maintenance.
Engineered wood, made of a plywood base with a hardwood veneer, is more stable and resistant to moisture, making it ideal for basements or kitchens. It’s also more affordable and easier to install, often using click-lock systems. However, its thinner veneer limits refinishing to one or two times.
Flooring pros often recommend engineered wood for versatility and cost-effectiveness, especially in moisture-prone areas. Solid hardwood is favored for high-traffic spaces or homes where classic aesthetics and longevity are priorities. Your choice depends on budget, climate, and aesthetic goals.
Both engineered and solid hardwood have unique strengths. Consult a flooring expert to assess your space and needs for the best decision.
