A pipe wrench is used to grip and turn pipes securely, making plumbing repairs much easier. A basin wrench reaches nuts behind sinks where space is tight. Pipe cutters slice metal or plastic pipes cleanly, while plumber’s snakes clear stubborn clogs from drains. Teflon tape seals threaded pipe joints to prevent leaks, and soldering torches join copper pipes with heat. Adjustable pliers provide a versatile grip, and pipe benders shape pipes without kinking them. Tubing cutters handle smaller pipes precisely, giving neat edges.
For electrical work, wire strippers remove insulation from wires safely, and voltage testers check if circuits are live. Multimeters measure current, voltage, and resistance, while fish tape guides wires through walls or conduits. Crimping tools secure connectors to cables, and insulated screwdrivers allow you to work safely on electrical fixtures.
These tools make plumbing and electrical tasks faster, safer, and more precise. Using the right tool for each job not only prevents mistakes but also ensures your renovation looks professional and functions properly. Investing in these essentials is a smart move for any homeowner or DIY enthusiast.
