Before any renovation work, it is important to evaluate the condition of the roof. During evaluation, the roof showed signs of material failure, including cracks, rust, and loose edges. These conditions explained the leakage problems noticed inside the building.
The evaluation involved observing both the roof covering and its supporting structure. Some timber members were weak, while others were still in good condition. The roof slope and drainage system were also assessed to understand how water moved across the surface.
Based on the evaluation, renovation work focused on critical areas. Damaged sheets were replaced, weak timber supports were reinforced, and proper fixing methods were applied. Drainage was also improved to reduce water retention. After renovation, the roof became more efficient and secure. Evaluating roofing conditions before renovation helped ensure that the right solutions were applied, improving performance and reducing future maintenance needs.
In conclusion, evaluating roofing conditions before renovation is a crucial step in achieving a successful outcome. A detailed assessment helps identify existing defects and their causes, ensuring that renovation efforts are focused on the most critical areas. By addressing issues such as damaged sheets, weak supports, and poor drainage, the renovation process becomes more effective and long lasting. Proper evaluation not only improves the performance and safety of the roof but also reduces the likelihood of recurring problems and unnecessary maintenance costs. This approach ensures that the renovated roof provides reliable protection and durability for the building over time.
