Basements are naturally cooler than the rest of your home, and that may result in increased heating costs if your basement isn’t properly insulated. Using the right exterior insulation materials can not only help shield basement walls from temperature variations, it can also make your home more energy-efficient.
Rigid foam boards are one of the best options. They are moisture resistant and have excellent thermal performance that keeps basement walls warm in winter and cool in summer. Spray foam insulation is also a good option, as it can fill in gaps and cracks and form a continuous barrier against air leaks and heat loss.
Insulating the outside of basement walls will stop cold bridges and it reduces the load on heating systems. This means that it keeps interiors more comfortable while reducing energy bills. Additionally, exterior insulation insulates the walls from condensation, and reduces the chance of mould growth, further maintaining the durability of the renovation.
Materials such as mineral wool or insulated panels can also be used, which provide fire resistance, soundproofing and moisture control. Combining insulation with waterproof coatings or drainage systems ensures that the basement will be dry, energy-efficient and comfortable all year long.
Exterior insulation is one investment in comfort and sustainability. Choosing long-lasting, moisture-resistant materials is important to keep the temperature steady, prevent damage and save money on energy Properly insulated basements are not only more livable - they are an important part of a long-lasting, efficient and worry-free renovation.
