Recently, I helped fix a leaking tap in our kitchen, and it turned out to be easier than I expected. The leak was coming from the base where the tap connects to the pipe, and it would drip constantly — wasting water and raising our bill. After doing a bit of research and asking a plumber friend, I found that the issue was most likely due to a loose or worn-out thread seal.
The fix was simple: I turned off the water supply, unscrewed the tap from the pipe, and wrapped Teflon tape (also called plumber’s tape) around the threaded section about 5–6 times. Then, I screwed the tap back in tightly. Once the water was turned back on, the leak had completely stopped.
Teflon tape is affordable, easy to use, and a must-have in any DIY toolkit. This small fix saved us from calling a plumber and spending extra money. It also gave me confidence to try other small plumbing tasks in the future.
If your tap is leaking from the joint, don’t panic — try this method first. It’s simple, clean, and surprisingly effective.
