One of the most flexible staging means in renovation is plants that add freshness, lusciousness, and life to the inside. In addition to aesthetics, greeneries enhance the quality of air as well as provide a relaxing environment, which makes the spaces friendlier to potential buyers or settlers. With a wiser use, even the simplest renovation will be turned into a bright and cozy dwelling with the help of plants.
In small rooms or kitchens, small sized plants like the succulents, herbs or small potted flowers can be used without overcrowding the surfaces. In residential spaces, bigger statement plants such as fiddle-leaf figs, snake plants, or palms are able to place corners and lines of architecture to a gentler state. By grouping plants of odd numbers, including threes, this creates a balance and visual interest and also by combining the heights of the plants, staging is brought to life.
Plants also perform well in the transitional areas. Hanging garden in a hall, a vertical garden on a walls niche in a dining area, or hanging plants on open shelfs will help to connect hall and dining areas and add a natural flow. Bathrooms also have a good environment with plants that are humidity-friendly such as ferns or orchids which do well in wet areas and give a spa-like quality.
The type of containers used is also a major consideration. Ceramic pots, woven baskets, and bare-boned planters can be used to enrich the styles of renovation that may be modern or rustic. Nonetheless, excessive use of greenery in a room may cause noise. It is all about balance, plants must highlight the renovation, not take the focus away.
Finding: Plants added in case of renovation add vitality into interiors. With the appropriate size, type, and location of the greenery, it becomes more comfortable, stylish, and fresh and makes renovated homes more natural, lively, and attractive to people who will live there.
