Great Lakes: which basement egress retrofits don’t leak—best wells and covers?
For window wells, choose tough composite or fiberglass ones they won’t rust or bend. Set them on drainage stone with a footing drain, and use a clear, hinged cover for rain protection and easy opening. Seal the wall joint with flexible flashing or sealant to prevent cracks from movement.
Best Egress Window Wells
-Tuffwell Window Well: Made from 19-gauge steel with a unique corrugation pattern, providing exceptional durability against heavy soil pressure.
-2060 Window Well: A one-piece unit designed for 4-foot wide egress windows, durable and easy to install.
Best Egress Window Covers
-Polycarbonate Window Well Cover: Durable, UV-resistant, and supports up to 500 pounds. Ideal for protecting basement windows from debris and weather.
-Aluminum Window Well Grate: Lightweight, rust-free, and allows natural light into the room. Can be custom-made to fit any size well.
