The Classic Cutting Tool
A handsaw is a traditional tool used to cut wood manually. It has a handle attached to a serrated metal blade, allowing you to make straight or angled cuts with control. Handsaws are ideal for smaller projects, detailed cuts, or areas where power tools are not practical.
To use a handsaw, secure the wood firmly on a stable surface or sawhorse. Grip the handle comfortably, align the teeth of the blade with the cut line, and use smooth, even strokes, letting the saw do the work. Avoid forcing it, as this can bend the blade or create rough edges.
Handsaws come in different types, including crosscut for cutting across the grain and rip saws for cutting along the grain. Even in a world of power tools, a handsaw remains reliable, quiet, and precise for many home renovation tasks.
