Heat‑pump clothes dryers: in tight condos, does ventless moisture control work well enough to be worth it?
Heat-pump dryers are great for condos since they don’t need a vent. They just pull moisture into a condenser and send it down the drain. They might make the room a tad warmer and humid, but not if the space is ok and has air moving. They’re slower than regular dryers but gentler on clothes and a much better option if venting isn’t possible.
