Home Renovations Cost Price list Hamilton
Comprehensive Price List for Home Renovation Services in Hamilton
As a seasoned home renovation expert, I’m excited to provide you with an in-depth guide to the costs associated with various home renovation services in Hamilton. This price list includes detailed descriptions of each service, realistic cost estimates, and insights into the factors that may influence these costs. Whether you’re planning a small project or a major renovation, this guide will help you budget effectively.
:bathtub: Bathrooms, Kitchens & Basements
Bathroom Remodel
Transforming your bathroom can enhance both comfort and property value. A typical bathroom remodel costs between $9,000 to $13,000, depending on the extent of the renovations, materials used, and labor costs. Key factors include the choice of fixtures, tiles, and whether you’re changing the layout.
Kitchen Remodel
Kitchens often serve as the heart of the home. A full kitchen remodel can range from $30,000 to $50,000. This price varies based on the quality of cabinets, countertops, appliances, and labor. Expect to pay more if you’re making significant changes to the layout or plumbing.
Basement Renovation
Renovating your basement can add valuable living space. Costs typically range from $20,000 to $50,000 depending on the scope of the project, such as adding a bathroom or kitchenette.
:house: Flooring - Hardwood, Carpet, Tile, Vinyl
Hardwood Flooring Installation
Installing hardwood floors can range from $8 to $15 per square foot, including materials and labor. The type of wood chosen significantly affects the price.
Carpet Installation
Carpet installation generally costs between $2 to $5 per square foot. This includes the cost of padding and labor.
Tile Installation
Tile installation can vary widely but typically ranges from $5 to $20 per square foot, influenced by the type of tile and complexity of the installation.
Vinyl Flooring
Luxury vinyl flooring is a cost-effective alternative, typically costing between $3 to $7 per square foot.
:art: Painting - Interior / Exterior
Interior Painting
Interior painting costs can range from $400 to $1,200 per room, depending on the size and complexity of the job. For a full home interior, expect to pay up to $10,000.
Exterior Painting
Exterior painting averages around $4,889 for a standard-sized home. Factors influencing cost include the condition of the surfaces and the type of paint used.
:window: Canadian Made Windows & Doors
Window Installation
The cost of installing new windows in Hamilton typically ranges from $400 to $2,100 per window, depending on the style, size, and materials used.
:wrench: Window Caulking and Capping
Caulking Windows
Professional caulking services typically cost between $50 to $70 per window. This service helps improve energy efficiency and protect against moisture.
Window Capping
Aluminum capping can add a polished finish to your windows and costs approximately $5 to $15 per linear foot.
:house: Roofing - Asphalt Shingles, Cedar, Metal
Asphalt Shingle Roofing
Asphalt roofing ranges from $5.50 to $12.25 per square foot installed. The type of shingles and labor costs will influence the final price.
Metal Roofing
Metal roofing costs between $4.50 to $16.00 per square foot, depending on the type of metal and installation complexity.
Cedar Shake Roofing
Cedar shake roofs can cost between $12,900 to $28,200 for installation, depending on the size and complexity of the roof.
:cloud_with_rain: Eavestrough, Leafguard, Soffit, Fascia
Eavestrough Installation
Eavestrough installation costs range from $6 to $12 per linear foot for aluminum gutters and $25 to $40 per linear foot for copper.
:fire: Chimney - Repair, Removal & Rebuild
Chimney Repair
Chimney repairs can vary widely, typically costing between $600 to $1,500. More extensive repairs, such as relining, can cost up to $7,000.
Chimney Removal
Removing a chimney generally costs between $1,000 to $3,000, depending on the complexity and structural implications.
:brick: Parging, Stone Facing, Siding
Parging
Parging costs about $10 to $20 per square foot, providing a smooth surface for waterproofing and enhancing aesthetics.
Stone Facing
Stone facing installation can range from $15 to $30 per square foot, influenced by the type of stone and installation method chosen.
:walking_man: Walkways, Steps & Railings, Porches
Walkway Installation
The cost of installing a concrete walkway averages $1,620, while paver walkways can range from $1,430 to $3,530.
Steps Installation
Stone steps typically cost between $30 to $65 per linear foot, depending on the material used.
:building_construction: Flagstone, Bricks Stone, Repair - Rebuild
Flagstone Installation
Installing a flagstone patio can cost between $5 to $25 per square foot, depending on the complexity of the design.
:office: Concrete Repair, Interlock Lift and Relay
Concrete Repair
Concrete repair costs typically range from $200 to $1,000, depending on the extent of the damage and the repair method used.
Interlock Repair
Interlock repairs can cost around $20 to $25 per square foot, depending on the materials and labor involved.
:motorway: Interlock Design and Installation
Interlock Installation
The average cost for interlock installation ranges from $20 to $25 per square foot, influenced by the design and materials selected.
:red_car: Driveways - Asphalt, Stone, Concrete
Asphalt Driveway
Asphalt driveways typically cost between $2.50 to $4.00 per square foot installed.
Concrete Driveway
Concrete driveways usually range from $3 to $12 per square foot, depending on the finish and complexity.
:deciduous_tree: Fencing, Landscaping and More…
Fencing Installation
Fencing costs can vary widely based on material and height, typically ranging from $15 to $50 per linear foot.
:house_with_garden: Enclosures, Car Ports, Awnings
Carport Installation
Metal carports in Hamilton can range from $1,950 to $7,200, depending on the size and style chosen.
:derelict_house: Foundation Repair - Basement Waterproofing
Foundation Repair
Foundation repair costs typically range from $2,000 to $7,000, depending on the severity of the damage and the methods used.
Basement waterproofing can cost between $100 to $300 per linear foot, influenced by the type of waterproofing method and materials used.
This comprehensive price list is designed to guide you through your home renovation journey in Hamilton. Remember, costs can vary based on specific project details, so it’s always best to consult with local professionals for accurate estimates and personalized advice. For further discussions and community insights, feel free to engage in local forums! :hammer_and_wrench::house_with_garden:
This message is hope itself, thank you.
