How do you prevent mold after a bathroom renovation?
What’s even mold lol I don’t quite know that
1. Ventilation
Install a good exhaust fan that vents outside, not just into the attic.
Keep the fan running during and after showers (10–15 minutes at least).
Open windows when possible to increase airflow.
2. Moisture Control
Wipe down wet surfaces after showers—especially tiles, glass, and countertops.
Fix any leaks immediately (faucets, pipes, showerheads).
Use waterproof or water-resistant materials, like porcelain tiles or moisture-resistant drywall (greenboard).
3. Material Choices
Choose non-porous tiles (porcelain, glazed ceramic, or glass) for walls and floors.
Use epoxy grout instead of standard grout; it’s mold-resistant.
Consider mold-resistant paint for ceilings and walls.
4. Routine Maintenance
Clean the bathroom weekly with a mild cleaner or vinegar solution.
Keep shower curtains or doors dry when not in use.
Inspect corners, grout lines, and behind vanities regularly for early signs of mold.
Combine everything we need here already Thanks
Thanks very much for the idea
That’s very true sir
Maintainece is a very good thing to do
Yeah brother glad you understand
Ensure proper ventilation, fix leaks immediately, use mold-resistant materials, and keep surfaces dry.
Hmmm that’s also part of it
Preventing mold after a bathroom renovation requires attention to detail, proper materials, and good maintenance practices. Here are some tips to help prevent mold growth:
During the Renovation;
Use Mold-Resistant Materials
Ensure Good Ventilation
Seal All Joints and Gaps
Use Waterproofing Membranes
Well detailed, Thank you brother
