How should renovators test and certify PFAS removal to avoid liability claims?
Test, remove PFAS using certified methods, keep records, retest, and tell the client. This protects you if PFAS becomes a problem later.
To test and certify PFAS removal effectively, renovators should follow these steps:
- Utilize EPA-approved testing methods, such as:
-EPA Method 8327: For detecting PFAS in liquid chromatography/tandem mass spectrometry (LC/MS/MS)
-EPA Method 537.1: For determining PFAA concentrations in drinking water
-EPA Method 1633: For detecting 40 PFAS compounds in various samples, including wastewater, surface water, and soil
Renovators should use accredited labs to test before and after work, follow certified PFAS removal methods, and keep detailed records to document compliance.
