Renovations can easily spiral out of budget if you are not careful. A renovation specialist recently shared five key decisions she regrets and how homeowners can avoid making the same mistakes.
One common issue is failing to plan a clear color scheme. Without it, mid project changes become costly and frustrating. Another regret was spending too much on designer light switches in every room instead of limiting them to key areas. It is often better to balance style with cost rather than splurge everywhere.
Choosing real limestone tiles was another mistake. While they look beautiful, they required expensive professional installation. Porcelain alternatives can create the same effect for less money and less hassle. Similarly, reclaimed roof tiles used in hidden areas turned out to be an unnecessary expense when cheaper substitutes would have worked just as well.
Finally, waste management often gets overlooked. Renovation projects produce large amounts of debris and failing to budget for skips or waste removal services can lead to surprise costs. Planning ahead for disposal saves both money and stress.
Final Thoughts
Renovation success is not about cutting corners but about making smart choices. Careful planning, realistic budgeting, and thoughtful material selection can help you achieve your dream home without draining your finances.
