Floating shelves add style and storage to any space without the cluttered look of brackets. Best of all, you can install them without damaging your walls, making them ideal for renters or those hesitant to drill. Here’s a simple guide to creating a no-damage floating shelf.
Materials Needed:
Wooden board (1-inch thick, cut to desired length)
Command Strips (heavy-duty, rated for your shelf’s weight)
Level, measuring tape, pencil
Sandpaper, paint, or stain (optional)
Wall-safe adhesive putty (optional for extra stability)
Step 1: Prep the Shelf Choose a lightweight wooden board, typically 12-24 inches long for stability. Sand the edges for a smooth finish and paint or stain to match your decor. Ensure the board is clean and dry for adhesive application.
Step 2: Plan the Placement Measure and mark the desired shelf height on the wall using a pencil (easily erasable). Use a level to ensure the marks are even. Test the placement by holding the shelf against the wall.
Step 3: Apply Adhesive Use heavy-duty Command Strips, rated for at least 15-20 pounds, depending on your shelf’s size and load. Follow the package instructions: attach strips to the back of the shelf, press firmly, and remove the protective backing. For added security, apply adhesive putty to corners.
Step 4: Install the Shelf Press the shelf firmly against the wall at the marked spot for 30 seconds. Check with a level to ensure it’s straight. Let the adhesive set for 24 hours before placing items on the shelf.
Step 5: Decorate and Maintain Add lightweight decor, keeping total weight within the strips’ limit. To remove, gently pull the Command Strip tabs downward to avoid wall damage.
This renter-friendly solution offers a sturdy, stylish shelf without a single hole
tips: follow the steps and avoid damaging your wall
