How to Build Floating Shelves for Extra Storage
Floating shelves are a stylish and functional way to add storage while keeping a room feeling open. Unlike traditional shelving units, they mount directly to the wall with hidden brackets, creating a sleek and modern appearance.
To begin, gather the right materials. You will need wood boards, wall brackets, screws, a drill, a level, and measuring tape. The wood can be stained, painted, or left natural depending on the design of the room.
Measure the wall carefully and mark where the shelves will go. Use a stud finder to locate studs, since securing brackets into solid wood ensures stability. Once studs are located, drill pilot holes and attach the brackets firmly. After brackets are secure, slide the wood boards into place.
Floating shelves can be made in different sizes and depths to fit the needs of the space. Narrow shelves work well in bathrooms or entryways, while deeper ones are ideal for kitchens and living rooms. Styling the shelves with plants, books, or artwork adds personality.
The entire process is manageable in an afternoon and requires only basic tools. The key is accurate measurement and leveling, which ensures the shelves are straight and able to hold weight safely.
Conclusion: building floating shelves is an easy DIY project that balances form and function. It adds useful storage while enhancing the design of any room in the home.
Thank you for this enlightening article
Thank you for this enlightenment
Insightful update
Keep going
Thanks for the heads up mate
Wow sounds so easy to do lol
Such a clever upgrade — love the design choices.
Thanks for sharing this update
This is really impressive
Make sure you continue with the good work friend
This really is very insightful
