How to Make Your Home More Energy-Efficient
Want a home that stays comfortable while saving on energy costs? Discover smart renovation tips for insulation, windows, solar power, and more with Refresh™ AU.
← Back to Inspiration & Advice
Modern Australian home with solar panels and energy-efficient features.
Imagine you’re sitting in your living room on a hot summer afternoon. The air conditioner is running, but you can still feel the heat sneaking in through the windows. In winter, it’s the opposite. The heater works all day, yet the cold still creeps inside. It happens in many Australian homes. Small things like thin walls, poor insulation, and old appliances can waste a lot of energy. You end up paying higher power bills while your home still doesn’t feel as comfortable as it should.
Let’s go through simple energy-efficient renovation tips to help you keep your home cosy, lower your bills, and use less energy.
Smart Renovation Steps to Cut Energy Use at Home
Making your home more energy-efficient doesn’t always mean big, expensive changes. Sometimes, small upgrades and smart planning can make a huge difference.
Here are some practical renovation ideas to help you keep your home comfortable all year, lower your bills, and reduce wasted energy.
Start with Insulation and Draft Sealing
Insulation is like a blanket for your home. Without it, warm air escapes in winter and cool air escapes in summer. It makes your heater and air conditioner work harder, costing you more money. When renovating, check the insulation in your ceiling, walls, and under the floors. Also, look for gaps around windows, doors, and vents where air might be leaking. Sealing these gaps with weather strips or sealant will make your home warmer in winter, cooler in summer, and cheaper to run.
Upgrade Windows and Use Smart Shading
Old single-pane windows can let a lot of heat in or out. Switching to double-glazed windows keeps your home’s temperature more stable. If replacing windows isn’t possible right now, you can still make improvements with thick curtains, blinds, or outdoor awnings. In summer, shading your windows with plants or pergolas can block harsh sunlight. In winter, letting sunlight in during the day will warm up your home naturally.
Really appreciate the insight brotherly
Renovation gives a home a personalized touch that reflects the owner’s style.
You are making sense
This is really such good work
What a good renovation insight
This is really innovative
Your positivity shines through—thank you for sharing this.
This is such a good tip
Good article buddy Thanks for this
Replacing windows definitely makes a statement
Thank you for sharing this
