How to Mount a TV on Brick Wall - This Old House https://share.google/wcFiIvTM3rDJYevrX
Tools & Materials You’ll Need
TV wall bracket (appropriate for your TV size and mount type)
Cordless hammer-function drill (avoid using an impact driver)
Masonry drill bits (specifically for brick/concrete surfaces)
Level, tape measure, permanent marker
Anchors or concrete screws
Use concrete screws for TVs over 75 lbs
Plastic wall anchors are fine for lighter TVs
Driver bits (e.g., #2 Phillips for anchors; #3 Phillips or socket set for concrete screws)
Washers (if screw holes are oversized)
Hammer or rubber mallet, shop vac (to clean dust), safety glasses, dust mask
Step-by-Step Installation
  1. Choose a Location
    Pick a spot close to an outlet and cable connections. Keeping cables minimal enhances the aesthetic.
  2. Determine Mounting Height
Attach the bracket to the TV (or simulate placement)
Measure from the TV’s bottom to bracket bottom
Add this to your desired TV bottom height to find the bracket height on the wall
  1. Mark Drill Holes
Use a level to align the bracket
Mark hole locations with a permanent marker
If marks fall on mortar lines, shift the position to hit the brick instead—mortar is weaker and can degrade over time
  1. Drill Holes into Brick
Use the hammer drill with masonry bit to drill clean, precise holes in the brick
Avoid mortar for longer-lasting hold
  1. Insert Anchors or Screws
For lighter TVs: plastic wall anchors suffice
For heavier TVs (over 75 lbs): use concrete screws
Use washers if needed to match screw head size to bracket holes
  1. Attach the Bracket
Secure the bracket firmly to the wall using screws or anchors
Ensure it’s level and tight against the wall
  1. Mount the TV
With help, lift the TV and hook it onto the bracket
Secure it as per the bracket design (e.g., locking screws or safety latches)
  1. Tidy Up
Clean up dust using your shop vac
Manage cables with cable raceways or conduits for a clean finish
Why Brick Can Be a Better Mounting Surface
Despite common concerns, brick is often sturdier than drywall when it comes to heavy mounting – it’s denser and more durable. However, mortar should be avoided due to its relative softness and tendency to deteriorate.
Extra Tips
Don’t mount too high—aim for eye-level viewing to prevent neck strain. Many users facing TVs mounted too high receive lighthearted (yet helpful) critiques on communities like r/TVTooHigh.
If mounting above a fireplace, consider:
Heat exposure damaging the TV
Viewing angle discomfort
The need for a tilting or articulating mount for better tilt Proper ventilation and cable management are also important.
Thanks for sharing this
Thanks for sharing this info
Nice DIY article bro :+1: :ok_hand:
This is so great This is so great Thank you for sharing
Thanks for sharing out this renovation tips.
thank you boss for the update
This is so interesting
i would try it out
Amazing article onyxx
Glad to come across this lad
