How to Replace a Bathroom Faucet
  1. *Turn off the water supply:* Make sure to shut off valves under the sink.
2. *Remove the old faucet:* Use a wrench to loosen mounting nuts and disconnect water lines.
3. *Clean the sink area:* Remove old plumber’s putty or debris.
4. *Install the new faucet:* Follow manufacturer instructions to secure it in place.
5. *Reconnect water supply lines:* Tighten connections, avoiding overtightening.
6. *Turn water back on:* Check for leaks and ensure proper water flow.
7. *Test and finish:* Clean the area and enjoy your updated bathroom fixture.
Simple faucet upgrades improve both style and function in your bathroom!
Gokd work brother :flexed_biceps::flexed_biceps:
Great work sir this is good
Grabbed a few points from this buddy
Thanks for sharing this buddy appreciate
Thank you for putting this out mate
You are always on point buddy
Keep up the good work buddy
This definitely a great work fr mate keep up
This very engaging ,
