Renovating a kitchen can feel overwhelming, especially when the space is small. The good news is that even on a budget, you can make big changes that improve both the look and function of your kitchen. The key is focusing on small details that create a big impact.
Start with the cabinets. Instead of replacing them, consider painting them in a light shade like white or soft gray. This instantly brightens the room and makes it feel more spacious. Swapping out the cabinet handles for modern designs can also give the kitchen a fresh and updated appearance.
Lighting is another area where small changes go a long way. Adding under-cabinet LED strips not only improves visibility when cooking but also makes the kitchen look more stylish. If you have room for a pendant light, it can serve as both task lighting and a design feature.
Countertops often feel like a huge expense, but there are affordable options like laminate or butcher block that look modern without the high price tag. Pair them with a simple backsplash, such as peel-and-stick tiles, for a clean and practical upgrade.
Final thoughts: A small kitchen does not need a huge budget to feel new again. By focusing on paint, hardware, lighting, and affordable surfaces, you can create a space that feels both functional and modern without overspending.
