How to waterproof house?
How can I effectively waterproof my house to prevent leaks and moisture damage? What steps should I take to ensure proper protection against water intrusion?
To effectively waterproof your house, start by checking the foundation for cracks and sealing them with epoxy. Install gutters and downspouts to direct rainwater away from the base. Consider adding a vapor barrier in crawl spaces and use waterproof paint on basement walls. Regularly inspect roofing and siding for damage. Always ensure proper drainage around your home!
