If your state adopts 2024 IECC, which residential measures change first at plan review, and where are most waivers gran…
If your state adopts 2024 IECC, which residential measures change first at plan review, and where are most waivers granted?
If your area uses the 2024 IECC, expect faster permit reviews. Inspectors will be checking if your plans meet energy goals which includes energy credits, airtightness, and insulation. Also, things like EV-readiness might show up if your locality uses optional code upgrades.
You probably won’t get waivers during the review phase. Instead, before the code is adopted, local officials can choose which parts are mandatory or adjust them to fit local needs. So, your plans will need to follow the main code and any local changes that make projects practical.
Planning to build or review plans under the 2024 IECC? Tell me your location, and I can research how they’ve applied the code and any flexible options available.
When adopting the 2024 International Energy Conservation Code (IECC), several residential measures will likely change first at plan review.
Waivers and Amendments
-State Amendments: States like Massachusetts and Vermont have adopted the 2024 IECC with local amendments, tailoring the code to their specific needs. Other states, such as Illinois, Nevada, and Rhode Island, have also adopted the code with varying levels of amendment.
-Waiver Provisions: While specific waiver provisions are not detailed, it’s likely that waivers will be granted for certain projects or circumstances, such as historic buildings or extreme hardship cases. The code’s flexibility provisions, like the “efficiency buffet” in Section R408, may also allow for creative compliance solutions.
