Exterior materials play a huge role in keeping basements safe, efficient and visually appealing. Insulation is one of the more important investments. Rigid foam boards and spray foam block heat loss while helping to prevent condensation on the walls, making the basement a comfortable place to live, while lowering energy expenses. Mineral wool provides an additional fire resistance and soundproofing and thus enhances performance.
To protect walls from weather, weather resistant paints are needed. Formulated to resist moisture, UV rays and varying temperatures, these paints provide protection for concrete or masonry against cracking, peeling and the growth of moulds. They also come in many different finishes which enables homeowners to have the best of both worlds when it comes to durability and design.
Proper drainage is part of the cornerstone of exterior protection. French drains - trenches filled with gravel and perforated pipes - break water away from foundations and relieves pressure on the walls and prevents them from leaking. When installed properly they can protect a basement for decades with very little maintenance.
For added strength and style, stone veneer adds a protective outer layer for added curb appeal. Lighter and less expensive than complete stone walls, veneers are moisture and impact resistant and add timeless elegance to basement exteriors.
Finally, corrosion-resistant metals guarantee that fixtures such as window wells, vents and railings resist damp conditions. Stainless steel, aluminium, and galvanised metals preserve their function and appearance and prevent rust from damaging the structures around them.
Exterior insulation, weather resistant paints, French drains, stone veneer and corrosion resistant metals work hand-in-hand to create a strong and efficient basement exterior. By combining protection with style, these materials ensure that basement renovations will be long-lasting, functional and attractive for many years to come.
