In well‑water hot spots (arsenic/uranium), which filtration methods work reliably for households?
If your well water has arsenic or uranium, reverse osmosis or special filters are your best bet, and sometimes using both is the way to go. Just make sure you test your water often so you pick the right setup and know when those filters need a change.
