Don’t forget waterproofing and insulation when you’re fixing up or building a place. If you don’t, you might get leaks, mold, big energy bills, and a not-so-cozy home. Luckily, there are new products out that can help keep your place safe, strong, and save energy.
Cool Waterproofing Stuff
- Paint-on stuff: Instead of sheets, you can paint this stuff to make a waterproof wall. Good for bathrooms, basements, and roofs.
- Sticky Sheets: These are easy to put up and keep water out. Just stick to walls or floors.
- Crystal Mix: Mix this with cement. It fills cracks with crystals when wet, helpful for basements and foundations.
New Insulation
- Spray Stuff: Fills holes and keeps air from leaking while keeping heat in. Great for attics and tough spots.
- Foam Boards: Light and doesn’t hold water. Works for basements and outside walls.
- Heat Reflectors: Uses foil to bounce heat. Good if you live somewhere hot to keep your place cool.
- Green Stuff: Made from old jeans, wool, or plants. Keeps your place comfortable and helps the planet.
In short
Waterproofing and insulation are now smarter, easier, and last longer. Putting them in when you redo your place can mean fewer fixes, smaller bills, and a healthier, comfier home.
