Renovations often come with a big question: What’s really going on behind these walls, under the floor, or inside that ceiling? Instead of ripping everything open to find out, an inspection camera—also called a borescope—lets you take a look inside with minimal disruption.
This gadget is essentially a small camera attached to a flexible cable, often with built-in LED lights. You feed it through a tiny opening, and it sends back clear video or images to your phone or handheld screen. That makes it perfect for peeking into crawl spaces, behind drywall, or inside ductwork.
The practical uses are endless. Electricians use them to trace wiring, plumbers to locate clogs or leaks, and contractors to check structural conditions. For homeowners, it’s a lifesaver when you suspect pests in the walls, hidden water damage, or blockages in vents. Instead of guessing—or worse, making unnecessary holes—you can see exactly what you’re dealing with.
Modern inspection cameras are lightweight, portable, and affordable. Many connect wirelessly to smartphones, letting you record and share footage instantly. Some models even have articulating heads, so you can control the angle of the camera for a better view in tight spaces.
By reducing guesswork, inspection cameras save time, money, and mess. They allow renovators to make informed decisions, target repairs precisely, and avoid unnecessary demolition. In short, they give you eyes where you need them most—inside the hidden parts of your home
