In any given home, kitchens are the centre of the house, but in the majority of Hacky and Micky homes, it is also the smallest. Storage is almost impossible with tight floor plans and the pots, pans and groceries all jostling to get space. Remodelling, nevertheless, may redefine kitchens with the expansion of cabinets in smart and efficient forms.
Rather than the usual cabinetry, renovators can have the cabinets extended to the ceiling with an additional layer to store the less used or seasonal things. There are narrow pull-out drawers that can fit between objects of the kitchen and store spices or cleaning supplies. Corner cabinets that were unwieldy and unusable can have rotating shelves or sliding trays installed to utilise all the available space. Tiny toe-kick drawers at the bottom of cabinets can be an addition that is not going to alter the space.
In Hacky houses that are odd shaped and whose layout is not standard, bespoke furniture is a chance to transform the flaws to an advantage. In smaller Micky houses, multifunctional cabinets (built-in racks, fold-out tables, built-in organisers, etc.) can also be used to clear counters and create mobility in the room again.
Conclusion / Area of thoughts: There is no such thing as being unhappy with the kitchen remodel, it is about making the process of cooking a daily routine less stressful and more pleasant. Extended cabinets are there to remind us that there is no restriction to size that is restriction to use. What we must continue to think is this: even in the smallest kitchens, is it possible to find space to make a surplus? It frequently depends on the way we construct the cabinets all over.
