Many renovation tasks require working above ground level, whether it’s painting ceilings, fixing roofs, or installing lighting. Ladders and scaffolding provide the access needed, but when used improperly, they can quickly become one of the biggest safety risks on a site.
A sturdy ladder is ideal for short tasks, but it must always be placed on a stable, level surface. Workers should avoid standing on the top rungs or overreaching, as this often leads to falls. Non-slip feet and securing the ladder at the top add extra stability.
For larger or longer projects, scaffolding is the safer option. Unlike ladders, scaffolds provide a broad, stable platform where workers can move freely with tools and materials. Guardrails and proper anchoring make scaffolding much safer for extended work at heights.
Both ladders and scaffolding should be inspected regularly for damage, as weak rungs, cracked frames, or loose fittings can lead to serious accidents. Choosing the right equipment for the job, and using it correctly, makes renovation work smoother and significantly safer.
