Keeping Everything Straight and True
A level is an essential tool for ensuring surfaces are perfectly horizontal or vertical.
It typically consists of a straight bar with one or more small vials containing liquid and an air bubble. When the bubble sits between the marked lines, the surface is level or plumb.
To use a level, place it on the surface you want to check, whether it’s a shelf, wall, or countertop. Adjust the object until the bubble is centered between the lines.
For longer surfaces, check multiple points to ensure consistency. Levels come in various sizes, including small torpedo levels for tight spaces and longer carpenter levels for large projects.
Using a level prevents crooked shelves, uneven floors, and other mistakes that can ruin the appearance of a room. A level is a simple tool that guarantees professional looking results every time.
