Hacky and Micky basement end up in dumping grounds after the dumping of sports equipment starting with soccer balls to hockey pads. Restocking a basement with specialised sports equipment lockers will change disorder into a system that is easy to use.
Air-conditioned lockers ensure that all the equipment is dry and odour free and shelves and hooks are used to arrange the helmets, gloves and uniforms. The smaller objects such as water bottles or shin guards are taken by the pull-out bins. Bike, ski or skateboard wall-mounted racks maximise floor space. Maintenance is easy as durable easy-to-clean finishes are used.
In Hacky homes with weird basements, lockers may be built into an alcove or a corner using the weird layouts. Modular lockers vertically arranged in smaller Micky houses give an ample storage space and do not overcrowd the house.
Conclusion / Area of thought: So, having sports lockers in the basement is a way of making sure that family life is made easier through organisation and minimization of chaos. The reflection: in case when correct storage can make athletics to be more pleasing and free of worries, what are the other everyday practises that can be made fresher and less stressful with the help of customised accessible systems?
