The roof renovation project was coordinated with a strong focus on solving persistent leakage issues. During inspection, I noticed cracked sheets, poorly fixed joints, and blocked drainage points. These defects explained the damp walls and ceiling stains inside the building.
After identifying the problem areas, I coordinated the renovation plan with the work team. Priority was given to sections with active leaks. Damaged roofing materials were replaced, and joints were properly sealed. Timber supports affected by moisture were reinforced to restore strength. Drainage channels were also cleaned and adjusted to prevent water buildup.
I monitored the renovation process closely to ensure materials were properly installed and aligned. After completion, test observations during rainfall confirmed that leakage had been successfully controlled.
Managing roof renovation with a focus on leakage control improves building comfort and safety. Proper coordination ensures that water related defects are permanently resolved.
